Developing with the S32K116 routines in the SDK cannot run offline mode every time after debug is over. I have checked START_FROM_FLASH, and now I suspect that the memory allocation and address of S32K116 48pin and 32pin are different (the chip I use is 32pin). Could you please give me a copy of S32K116 32pin routine with SDK, or please help me analyze where else I can go for investigation
已解决! 转到解答。
 Robin_Shen
			Robin_Shen
Seems that you already refer to did not run without debugger
Please import hello_world_s32k116 example of S32K1 SDK403 in S32DS v3.4 and switch package.
If there is no external 8MHz crystal, please disable it in Clocks tool.
Robin
 Robin_Shen
			Robin_Shen
Robin
