S32K Software Development Kit (SDK)
7,636 次查看
javiervicandi
Where is this tool available?
We probably will use the S32K144 microcontroller with Iar Workbench.
3,771 次查看
stanish
Hello Javier,
S32 SDK v0.8.1(EAR) is available as a part of S32DS installer. You can download it here:
http://cache.nxp.com/files/software_development_tools/ide-debug/S32DS-ARM.html
after the installation you can find SDK folder here:
c:\Freescale\S32_ARM_v1.2\S32DS\S32_SDK_EAR_0.8.1
If you'd like to develop your project in Eclipse environment + IAR build tools you can use S32DS + IAR Eclipse Plug-in. S32DS also includes graphical configuration tool (Processor Expert UI) to generate your configuration.
Hope it helps.
Stan
3,771 次查看
enwei
HI Stan,
Can S32DS support IAR Eclipse Plug-in, how to install it?
I tried the method as IAR recomend, but failed, cannot find IAR Embedded Workbench plugin manager: under help after installed plugin manager as it suggested:
IAR Embedded Workbench for Eclipse ;
Enwei.
