Recommended SDK and GCC versions for compilation
1,036件の閲覧回数
vikin
SDK Version: S32_SDK_S32K1xx_RTM_4.0.2
S32 Design Studio for S32 Platform IDE Version: 3.4
In the IDE there are two compiler versions available: GCC 6.3 for Arm and GCC 9.2 for Arm. Based on the SDK and IDE version information that have provided, which compiler version would you recommend using?
Looking forward to your reply.
1,020件の閲覧回数
Senlent
Hi@vikin
you should able find this document in your install path :"S32 SDK Release Notes Version 4.0.3 RTM"
1,021件の閲覧回数
Senlent
Hi@vikin
