Re: Require procedure for using the SDK RTM V3.0.3
1,455 次查看
vijaysubramanian
I am getting the below error, while Installing the software KSDK 1.1.0
An error occurred while collecting items to be installed
session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=null --> [R]com.freescale.processorexpert.ksdk-1.1.0.sp_root 1.0.0.b141204, action=).
The required Touchpoint: com.freescale.updater.touchpoint 1.0.0 touchpoint for the collect action is not included in the installation manager configuration.
Could you pls provide the solution.
1 回复
1,020 次查看
mohammad_saad
@addiyi
I'm facing the same problem as well.
Can you please help resolve this issue?
