RTM SDK V1.0.0 Update to latest SDK
1,088件の閲覧回数
davidmdrouin
I have an existing MPC5744P project developed using RTM SDK V1.0.0 and I would like to upgrade it to the latest SDK -- which I believe is RTM 3.0.0.  Are these two versions compatible?  What is the procedure to make the upgrade?
Thanks!
990件の閲覧回数
PetrS
guess that only SDK update possibility is create empty project with latest SDK version, move your code into project and manually set parameters for modules in processor expert.
BR, Petr
