RSDK_S32DS_template_LAX
ソリューションへジャンプ
1,548件の閲覧回数
OPSofiane
Hello All,
I created a new project from the 'RSDK_S32DS_template' example and ran ExampleProcLAX(); the example works, performing an addition of two vectors. However, when I try to modify the example, for instance by changing the vector length (BUF_LEN) to 130, the value is ignored and the size remains limited to 128. I've changed BUF_LEN in all files (A53 and LAX). I don't understand the logic behind the creation of the graph, what am I missing?
Thank you in advance
OPSofiane
タグ(1)
1,472件の閲覧回数
OPSofiane
Hello Perter,
Thank you for your reply.
The problem is temporarily solved, there is a cache memory pb, you have to manually delete the binary file in the S32DS IDE.
OPSofiane
2 返答(返信)
1,473件の閲覧回数
OPSofiane
Hello Perter,
OPSofiane
1,480件の閲覧回数
petervlna
I have contact our RADAR team. I will feedback you ASAP.
Peter
