Missing file in RTM 3.0.0 EEPROM Emulation driver demo
Search instead for
Hi all,
    I am studying the EEPROM emulation middleware. It was found a demo project in S32_SDK_RTM 3.0.0. The project defined configurations in the file "eee1.h"  However, the file could not be found the SDK folder. Could anybody provide this file?
Morris
"eee1.h" and "eee1.c" are generated files and appears in project's "Generated_Code" folder upon Procesor Expert generates a code.
BR, Petr
BR, Petr
Hi Petr,
    It seems S32DS V1.2 could not generate these files for the MCU S32R372. I modified the file from generated code for MPC574x and it was worked. Thanks for your help.
BR,
Morris
Hi Daniel,
The MCU is S32R372. The IDE is S32DS v1.2.
Morris
Hi Morris,
Please specify the MCU and the S32 Desing Studio version,
Thank you,
BR, Daniel
