Dear Jiri Kral
It works.
>> Did you generate Processor Expert code before you start build?
Yes, I have generate Processor Expert code before start build and it's not any error, even I don't add the "linflexd_uart".
My step as below.
1. import sample code.
2. Build Configuration → Set Active → Debug_Flash
3. Generate processor expert then start build.
As you see, I don't add "linflexd_uart". it's not any errors.
4. I double click the "enetif.c" file then it will show many error.
Kris
