I2C interface with S32k146 temperature sensor (TMP1075)
6,702 次查看
Jeevitha
I am trying to interface the temperature sensor(TMP1075) slave address- (0x49). I am not able to read the temperature value. I am getting a 00 value consistently. I have attached my code please help me. I am new to this board.
9 回复数
6,633 次查看
Jeevi
Hi, @VaneB to read the value of the temperature sensor, I shifted the slave address. I am able to communicate the same TMP1075 with other development boards I am not able to communicate with the S32K146 board. Once again can you check with my code?
6,624 次查看
VaneB
Hi @Jeevi
Our driver supports 10-bit and 7-bit slave address sizes. In the case of 7 bits, our driver does the bit shift, so you do not have to do it.
6,588 次查看
Jeevi
HI @VaneB Thanks for the information. I have changed the slave address. Now also I am not able to read the temperature value from the sensor.
6,577 次查看
VaneB
Hi @Jeevi
Could you provide an image of the I2C frame?
6,671 次查看
VaneB
Hi @Jeevitha
I have a question about why you shifted the slave address.
The communication from the S32K1 looks correct. So, I suggest you contact your device supplier to verify the required process and steps to work with the sensor.
B.R.
VaneB
6,407 次查看
Jeevi
Hi @VaneB I am using the lpi2c_master program I want to test the i2c communication so I am using the development board as master and the temperature sensor as slave. I want to read the data from the register(0x01). I am not able to read the temperature value from the sensor. I have tried many methods but it is not working. Can you please help me? I have attached the frame format also.
6,362 次查看
VaneB
Hi @Jeevi
Check section 3.1.12 (Reserved addresses) of the I2C-bus specification and user manual. This document mentions that the address 0000 001 is included.
Please verify the address required for your external device with your device distributor.
6,339 次查看
Jeevi
Hi @VaneB Thank you for the information. Can you please provide an example code for measuring the temperature data from the sensor?
6,324 次查看
VaneB
Hi @Jeevi
The examples we provide for I2C are the ones provided with the SDK and RTDs, and also the is one in the following link:
S32K Examples
