SPT is supported as any secondary core. You have to open SPT instance.
Here you can set breakpoint, run code, step code, to see OPRAM or TRRAM in memory window..
Exactly the same as any any other secondary core.
What is the address and memory space?
Which device are you asking for?
Peter
