How to import a Reference Program S32K144 of S32_SDK_RTM_3.0.0 into MULTI IDE 7.1.6 with Green Hills Compiler?
845件の閲覧回数
3131734215
   1. MULTI IDE 7.1.6 is Installed.My Board is NXP S32K144EVB-Q100.
    2. 30-day Green Hills Compiler license  for MULTI ARM v7.1.6 is successful.
    3. RTM 3.0.0.exe is installed, the installed path is C:\NXP\S32_SDK_RTM_3.0.0.
    4.I created a new project, I refer to the 《S32SDK_for_S32K1xx_RTM_3.0.0_ReleaseNotes.pdf》,GHS Compiler and Linker and Assembler Options are already set
    5.How to import  a Reference Program of  S32_SDK_RTM_3.0.0 into MULTI IDE 7.1.6 ?
            The path of a Reference Program of  S32_SDK_RTM_3.0.0 such as:
                  C:\NXP\S32_SDK_RTM_3.0.0\examples\S32K144\driver_examples\communication\uart_pal_echo
            I can not find the Cpu.h file in the  C:\NXP\S32_SDK_RTM_3.0.0\,Can you help me?
          The compilation information is in attachment.
754件の閲覧回数
lukaszadrapa
Hi Lin,
S32DS supports GHS toolchain. That means you can create project in S32DS, you can use SDK and processor expert. You will just use linker and compiler from GHS.
It's not expected use-case to port whole project into GHS IDE. You would lose main advantage - processor expert.
Lukas
