Hi.
I am implementing that the firmware of bootloader to the specific address of sram in S32K3.
It takes long time to copy into sram using memcpy.
Could you please let me know if there are any ways to copy into sram?
Hyunung Park
Solved! Go to Solution.
Thank you for your response.
BRs.
Hi @HyunungPark1
what about DMA? If it is copied to RAM by DMA, it will also take some time but you can start the DMA as soon as possible and the execute other initializations in parallel. This could improve the total time.
Lukas
