How can I get the last SDK version for S32K144
4,399 次查看
pengchenbing
Dear support team,
   How and where can I get the last SDK version for S32K144 ?
   And I create a new S32DS projection in DS32 , but none components can I add to it ,I want add FreeRTOS component to it .
3,308 次查看
stanish
Hello Peng,
I'd recommend you to install the latest update (S32 Design Studio for Arm v2.0 - Update 2 available)
It includes the latest S32K14x SDK v0.8.5 EAR - see the release notes attached with the release announcement for more details about features and "What is new".
Stan
3,309 次查看
stanish
Hello Peng,
Stan
3,308 次查看
jiri_kral
On main menu bar click on File -> New S32DS Application project
Select S32K144 device and put unique project name
In next step select S32K144 SDK:
Double click on processor expert and add FreeRTOS component. Don't forget generate Processor Expert code.
Change FPU instructions settings by right click on project name -> properties
Other way is use and modify FreeRTOS example.
Jiri
