Could you provide the document, "S32K144EVB hands on training" about LIN?
Search instead for
kbj
I use S32DS for ARM.2018.R1 and SDK EAR 0.8.6.
Byungju.
Tags (4)
mikedoidge
Hello kbj@hlgroup.co.kr‌,
Do you know if such document exists?
I am unaware of any such document. All I can find is the following document on CAN: Enabling Technologies: Hands-On Workshop: S32 SDK for S32K
I suggest that you look into the provided example projects for LIN: lin_master_s32k144 and lin_slave_s32k144.
Hope it helps,
Mike
kbj
Dear Mike,
Thanks for your response.
I saw an example but I did not understand it in detail and requested a training document.
I will look at the example code and ask again.
Byungju.
mikedoidge
Please make sure to check the following documents which may provide some more understanding of the LIN stack:
S32SDK_S32K14x_RTM_2.0.0/doc/html/lin_slave_s32k144_group.html S32SDK_S32K14x_EAR_2.0.0/doc/html/lin_master_s32k144_group.html
S32SDK_S32K14x_EAR_2.0.0/doc/html/group__lin.html
You should be able to locate them in the S32DS installation directory. (C:\NXP\S32DS_ARM_v2018.R1\S32DS)
Mike
kbj
Hi Mike,
Thanks for your help.
It seems to be helpful to me.
Byungju.
