why J-link can't connect to S32K118 that never be programmed before?
1,529件の閲覧回数
jianmin_zhou
hi,
When i use a new board with S32K118 chip that never be programmed before, S32DS always reports "no source at '0x00', but after i change PE 's debugger- MULTILINK, it's ok, then i change to J-link ,it's ok.  I don't know why? is there one know this reason?
タグ(3)
1,395件の閲覧回数
jiri_kral
You can try to download latest j-link software - SEGGER - The Embedded Experts - Downloads
Also don't forget modify j-link path to gdb server:
how to specify J-link path for S32DS?
If it doesn't help - try to ask on Segger forum:
SEGGER - Forum
Hope it helps.
Jiri
