whether S32DS_Power_Win32_v2.1 supports real-time observe expression through PE
已解决
跳至解决方案
1,757 次查看
ZEROOO
Hi everyone
   I use THE S32 DS to want to observe variables in real time through the PE.However, after the PE plug-in is installed, it is found that the debugging can only be suspended and then observed.Is there a way to complete online observation through PE and S32?If so, please tell me what to do.
   Best wishes!
1 解答
1,736 次查看
lukaszadrapa
this feature is available only for ARM devices in S32DS. In case of MPC5xxx devices, it's supported by hardware/MCU but not by S32DS (PE). The only option is to use advanced debuggers (like from Lauterbach...).
Lukas
在原帖中查看解决方案
1 回复
1,737 次查看
lukaszadrapa
Lukas
