Hi everyone
I use THE S32 DS to want to observe variables in real time through the PE.However, after the PE plug-in is installed, it is found that the debugging can only be suspended and then observed.Is there a way to complete online observation through PE and S32?If so, please tell me what to do.
Best wishes!
已解决! 转到解答。
this feature is available only for ARM devices in S32DS. In case of MPC5xxx devices, it's supported by hardware/MCU but not by S32DS (PE). The only option is to use advanced debuggers (like from Lauterbach...).
Lukas
Lukas
