whether S32DS_Power_Win32_v2.1 supports real-time observe expression through PE
1,760件の閲覧回数
ZEROOO
Hi everyone
   I use THE S32 DS to want to observe variables in real time through the PE.However, after the PE plug-in is installed, it is found that the debugging can only be suspended and then observed.Is there a way to complete online observation through PE and S32?If so, please tell me what to do.
   Best wishes!
1,739件の閲覧回数
lukaszadrapa
this feature is available only for ARM devices in S32DS. In case of MPC5xxx devices, it's supported by hardware/MCU but not by S32DS (PE). The only option is to use advanced debuggers (like from Lauterbach...).
Lukas
1,740件の閲覧回数
lukaszadrapa
Lukas
