S32K144,S32DS for Arm 2.2
Could you give some documents about PE?Thanks.
1.<<processor expert software-Microcontrollers Driver suite>> <<processor expert Driver suite-Getting Started Guide>>is really out of date
Solved! Go to Solution.
You can read Doxygen Documentation of S32K SDK.
Since you can read Chinese, it is recommended to follow this WeChat account 汽车电子expert成长之路.
By the way, it is recommended to use the latest S32DS v3.4 with S32K1 SDK 4.0.3 or S32K1 RTD 1.0.1. The new version software will fix the problems found in the old version.
Robin
Robin
没找到clockMain1:clock manager的配置介绍,能麻烦给个链接么?
