HI,I use s32ds create a project ,add freertos and flexcan ,when i debug it ,i find that ,only mailbox 1 can use receive ,when i use other mailbox ,it can not work
anyone can help me?
Solved! Go to Solution.
i have resolved this problem
the can struct must be globle variable or static variable
not be local variable
thank you
what's your S32DS version and target MCU?
Jiri
