s32ds flexcan only mailbox 1 can use receive
1,698 次查看
yongwan
HI,I use s32ds create a project ,add freertos and flexcan ,when i debug it ,i find that ,only mailbox 1 can use receive ,when i use other mailbox ,it can not work
anyone can help me?
1,624 次查看
yongwan
i have resolved this problem
the can struct must be globle variable or static variable
not be local variable
thank you
1,624 次查看
jiri_kral
what's your S32DS version and target MCU?
Jiri
1,625 次查看
yongwan
thank you
