s32ds Can't open,I uninstalled, and then re-install, still can not open
jason_qian
mikedoidge
Hello @jason_qian ,
The entitlement for this product on your account was recently extended to the year 2025, but the license won't update until it is returned. Due to the issue you are experiencing, you will not be able to do this in the tool. It is preventing you to access that menu. I have returned the licenses for you. You will need to reset the trusted storage and then reactivate each PC where you have installed the S32DS for ARM v2.2. To reset the trusted storage:
delete C:\ProgramData\FLEXNet.
Please let us know if you continue to have an issue after you have done this.
Mike
