how to set the yuv422 ouput format
2,263 次查看
huangzhong
I have problem in setting the yuv422 output format , our carema image data format is YUYV YUYV ......, and the S32V234 default format is UYVY UYVY ......, so what should I do to set S32V234 out format to YUYU.
(I had try to change the " mScreenInfo.grayscale = V4L2_PIX_FMT_UYVY", but it did not work).
        Look forward to your reply, Thank you very much!
标签 (3)
3 回复数
1,909 次查看
huangzhong
Yes, my cameras  are maxim ov10640 , and the graph is referfence to ov10635 demo, just like this:
and the image in lcd is:
our yuv422 data format is YUYV YUYV ........
1,909 次查看
jiri_kral
the ov10635 camera has built-in Debayer, but from ov10640 you are getting raw data. You need to put in your ISP graph Debayer box. You can look at ov10640_12bcomb_surround example for inspiration.
Jiri
1,909 次查看
jiri_kral
which camera are you using - OV10640? Are you using ISP graph tool?
Jiri
