i open a example named "lpspi_transfer".
then i add some components in the project.
so it change to my own project,but the name is still "lpspi_transfer".
i want to change a new name,how can i do it?
Solved! Go to Solution.
I tried with S32DS 1.3 and it works the same way. If the project is created in S32DS v1.3, choose the project, click rename and insert new project name.
Martin
if you use S32 Design Studio v2.0 and project is created in this version of S32DS, choose the project you want to rename, click File and choose rename. Please see the figure below:
Martin
martin:
for the V1.3 S32DS,is there some measures can solve the problem?
Martin
oh,That's amazing.thank you very much.
