Why this "powerpc-eabivle-gcc.exe: error: : No such file or directory"fault appear?
3,545 次查看
timwang
I can build successfully for about 5 times,but the sixth try failed,why?5.png
标记 (4)
2 回复数
3,143 次查看
jiri_kral
probably some temporary issue with user rights? It looks like that gcc compiler can't be found. Location on this executable file is [YOUR_INSTALL_PATH]\S32DS_Power_v1.2\Cross_Tools\powerpc-aebivle-4_9\bin . Please check if the file powerpc-eabivle-gcc.exe is present and accessible in this directory.
Jiri
3,143 次查看
timwang
Hi Jiri,
Thank you for you reply.
I solved this problem by deleting the debug folder and rebuild the project,i checked the powerpc-eabivle-gcc.exe and i am sure that this file existed when this fault appeared.
I don't know why this fault appeared inexplicable.
I built successfully many times and this fault just appeared suddenly.
It make me so confused.
Hope to get your help if this fault appears again.
