Who can share some documents or materials about the introduction of linker files, such as S32K148_256_ram.ld & S32K148_256_flash.ld?
And, where to find the assemble instructions doc of S32's Starup.S file?
Thanks!!!
解決済! 解決策の投稿を見る。
You can find the GCC build tools manuals in the S32 design studio installation folder
GCC v6.3
<S32DS_ARM_v2018.R1>\Cross_Tools\gcc-6.3-arm32-eabi\arm-none-eabi\share\docs\pdf
GCC v4.9
<S32DS_ARM_v2018.R1>\Cross_Tools\gcc-arm-none-eabi-4_9\share\doc\gcc-arm-none-eabi\pdf
there is linker manual: ld.pdf
Section: Linker Scripts
Hope it helps.
Stan
GCC v6.3
GCC v4.9
Hope it helps.
Stan
OK!
Thanks very much!
