Where can I find the EEPROM Emulation Driver for S32K3XX
Riyasma07
I want to emulate the internal Data Flash as EEPROM. For that EEPROM emulation driver is needed. Regarding EEPROM emulation, it was mentioned in the datasheet also. I don't know where to get that driver and what was the driver name. For Example: for internal flash the driver name is C40, for GPIO it is Siul2_Port.
Djuric
Did you manage to find an non AUTOSAR example of code that deals with this topic. Or any code example that works?
VaneB
Hi @Riyasma07
Check the following post. It has information related to the topic that will be useful.
EEPROM Emulation on S32K12 Controller
B.R.
VaneB
