How to use #pragma in S32 DS ...i want to create a constant to be located at a particular memory of flash
Solved! Go to Solution.
there are no pragmas in S32DS. Please see the document below, which shows, how to achieve your requirement.
https://community.nxp.com/docs/DOC-342073
Martin
Thank you Mr.Martin Kovar . It worked!!
