Update the reference Component in S32 Design Studio for ARM
864 次查看
satish_k_singh
Hello ,
Currently I am working with the S32K148 EVAL board and am using the I2CMaster project from the example.
In the configuration of the lpi2c seen in the component inspector , it makes use of the osif1 as the OS.
I would like to use the FreeRTOS as the OS , and I have included the same but I am not able to change.
So could would please let know how can I add and change the referenced component.
标记 (2)
733 次查看
ovidiualexandru
Hello Satish,
OSIF component is an abstraction layer for either FreeRTOS or baremetal environments. When adding FreeRTOS into a project, it is not necessary to disable osif. It will detect FreeRTOS and reconfigure itself to use osif_freertos.c variant.
Please enable osif in your project and add FreeRTOS, as Martin mentioned.
Ovidiu
733 次查看
satish_k_singh
Hello Martin,
Yeah I have disabled it , Currently the module lpI2c which I am working with refers the osif OS as the shared component , I want to update the shared component of the lpi2c from osif -----> FreeRTOS to use FreeRTOS features in the lpi2c , but I am not able to update the same.
so could you please let know how to go about updating the same.
thanks and best regards!!!
Satish Kumar
733 次查看
martin_kovar
it looks like you disabled osif component in your project. Please enable the component again and simply add FreeRTOS component into your project.
Martin
