Attachment didn't seem to work, here's the strace log in case it's useful.
execve("./arm-none-eabi-gdb-py", ["./arm-none-eabi-gdb-py", "--version"], 0x7ffe77c776a8 /* 47 vars */) = 0
brk(NULL) = 0x555be38ac000
arch_prctl(0x3001 /* ARCH_??? */, 0x7ffd41ec3570) = -1 EINVAL (Invalid argument)
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=80035, ...}) = 0
mmap(NULL, 80035, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f1841676000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libncursesw.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\221\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=231504, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f1841674000
mmap(NULL, 233912, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f184163a000
mmap(0x7f1841642000, 159744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x7f1841642000
mmap(0x7f1841669000, 36864, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2f000) = 0x7f1841669000
mmap(0x7f1841672000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x37000) = 0x7f1841672000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libtinfo.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \347\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=192032, ...}) = 0
mmap(NULL, 194944, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f184160a000
mmap(0x7f1841618000, 61440, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x7f1841618000
mmap(0x7f1841627000, 57344, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x7f1841627000
mmap(0x7f1841635000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2a000) = 0x7f1841635000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220q\0\0\0\0\0\0"..., 832) = 832
pread64(3, "\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\232e\273F\236E\241\306\373\317\372\345\270*/\327"..., 68, 824) = 68
fstat(3, {st_mode=S_IFREG|0755, st_size=157224, ...}) = 0
mmap(NULL, 140408, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f18415e7000
mmap(0x7f18415ed000, 69632, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f18415ed000
mmap(0x7f18415fe000, 24576, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f18415fe000
mmap(0x7f1841604000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c000) = 0x7f1841604000
mmap(0x7f1841606000, 13432, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f1841606000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \22\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=18848, ...}) = 0
mmap(NULL, 20752, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f18415e1000
mmap(0x7f18415e2000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f18415e2000
mmap(0x7f18415e4000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f18415e4000
mmap(0x7f18415e5000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f18415e5000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libutil.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\23\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14880, ...}) = 0
mmap(NULL, 16656, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f18415dc000
mmap(0x7f18415dd000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f18415dd000
mmap(0x7f18415de000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f18415de000
mmap(0x7f18415df000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f18415df000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \341\t\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1956992, ...}) = 0
mmap(NULL, 1972224, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f18413fa000
mprotect(0x7f1841490000, 1290240, PROT_NONE) = 0
mmap(0x7f1841490000, 987136, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x96000) = 0x7f1841490000
mmap(0x7f1841581000, 299008, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x187000) = 0x7f1841581000
mmap(0x7f18415cb000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d0000) = 0x7f18415cb000
mmap(0x7f18415d9000, 10240, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f18415d9000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300\323\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1369384, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f18413f8000
mmap(NULL, 1368336, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f18412a9000
mmap(0x7f18412b6000, 684032, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x7f18412b6000
mmap(0x7f184135d000, 626688, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb4000) = 0x7f184135d000
mmap(0x7f18413f6000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14c000) = 0x7f18413f6000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\3405\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=104984, ...}) = 0
mmap(NULL, 107592, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f184128e000
mmap(0x7f1841291000, 73728, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f1841291000
mmap(0x7f18412a3000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x7f18412a3000
mmap(0x7f18412a7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x18000) = 0x7f18412a7000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300A\2\0\0\0\0\0"..., 832) = 832
pread64(3, "\6\0\0\0\4\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0"..., 784, 64) = 784
pread64(3, "\4\0\0\0\20\0\0\0\5\0\0\0GNU\0\2\0\0\300\4\0\0\0\3\0\0\0\0\0\0\0", 32, 848) = 32
pread64(3, "\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\7\2C\n\357_\243\335\2449\206V>\237\374\304"..., 68, 880) = 68
fstat(3, {st_mode=S_IFREG|0755, st_size=2029592, ...}) = 0
mmap(NULL, 2037344, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f184109c000
mmap(0x7f18410be000, 1540096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x22000) = 0x7f18410be000
mmap(0x7f1841236000, 319488, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x19a000) = 0x7f1841236000
mmap(0x7f1841284000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e7000) = 0x7f1841284000
mmap(0x7f184128a000, 13920, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f184128a000
close(3) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f184109a000
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f1841097000
arch_prctl(ARCH_SET_FS, 0x7f1841097e80) = 0
mprotect(0x7f1841284000, 16384, PROT_READ) = 0
mprotect(0x7f18412a7000, 4096, PROT_READ) = 0
mprotect(0x7f18413f6000, 4096, PROT_READ) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f1841095000
mprotect(0x7f18415cb000, 45056, PROT_READ) = 0
mprotect(0x7f18415df000, 4096, PROT_READ) = 0
mprotect(0x7f18415e5000, 4096, PROT_READ) = 0
mprotect(0x7f1841604000, 4096, PROT_READ) = 0
mprotect(0x7f1841635000, 16384, PROT_READ) = 0
mprotect(0x7f1841672000, 4096, PROT_READ) = 0
mprotect(0x555bdb281000, 339968, PROT_READ) = 0
mprotect(0x7f18416b7000, 4096, PROT_READ) = 0
munmap(0x7f1841676000, 80035) = 0
set_tid_address(0x7f1841098150) = 99521
set_robust_list(0x7f1841098160, 24) = 0
rt_sigaction(SIGRTMIN, {sa_handler=0x7f18415edbf0, sa_mask=[], sa_flags=SA_RESTORER|SA_SIGINFO, sa_restorer=0x7f18415fb420}, NULL, = 0
rt_sigaction(SIGRT_1, {sa_handler=0x7f18415edc90, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART|SA_SIGINFO, sa_restorer=0x7f18415fb420}, NULL, = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, = 0
prlimit64(0, RLIMIT_STACK, NULL, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
brk(0x555be38cd000) = 0x555be38cd000
getrusage(RUSAGE_SELF, {ru_utime={tv_sec=0, tv_usec=3471}, ru_stime={tv_sec=0, tv_usec=0}, ...}) = 0
openat(AT_FDCWD, "/usr/lib/locale/locale-archive", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=5699248, ...}) = 0
mmap(NULL, 5699248, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f1840b25000
close(3) = 0
openat(AT_FDCWD, "/proc/self/fd", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
fstat(3, {st_mode=S_IFDIR|0500, st_size=0, ...}) = 0
getdents64(3, /* 6 entries */, 32768) = 144
getdents64(3, /* 0 entries */, 32768) = 0
close(3) = 0
ioctl(0, TCGETS, {B38400 opost isig icanon echo ...}) = 0
getcwd("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/bin", 4096) = 62
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/bin/arm-none-eabi-gdb-py", {st_mode=S_IFREG|0775, st_size=15366192, ...}) = 0
stat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/bin/../arm-none-eabi", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat("/usr/local", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat("/usr/local/NXP", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/usr/local/NXP/S32DS.3.6.0", {st_mode=S_IFDIR|0777, st_size=4096, ...}) = 0
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/bin", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/arm-none-eabi", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
stat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/bin/../lib/debug", 0x7ffd41ec3170) = -1 ENOENT (No such file or directory)
lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat("/opt/nxp", 0x7ffd41ec2070) = -1 ENOENT (No such file or directory)
stat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/bin/../share/gdb", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/share", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/share/gdb", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
stat("/usr/local/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat("/usr/local/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
rt_sigprocmask(SIG_BLOCK, NULL, [], = 0
rt_sigaction(SIGHUP, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGINT, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGQUIT, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGILL, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGTRAP, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGABRT, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGBUS, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGFPE, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGKILL, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGUSR1, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGSEGV, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGUSR2, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGPIPE, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGALRM, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGTERM, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGSTKFLT, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGCHLD, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGCONT, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGSTOP, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGTSTP, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGTTIN, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGTTOU, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGURG, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGXCPU, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGXFSZ, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGVTALRM, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGPROF, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGWINCH, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGIO, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGPWR, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGSYS, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_2, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_3, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_4, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_5, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_6, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_7, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_8, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_9, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_10, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_11, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_12, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_13, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_14, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_15, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_16, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_17, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_18, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_19, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_20, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_21, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_22, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_23, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_24, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_25, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_26, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_27, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_28, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_29, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_30, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_31, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGRT_32, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
sigaltstack({ss_sp=0x555be38c5140, ss_flags=0, ss_size=8192}, {ss_sp=NULL, ss_flags=SS_DISABLE, ss_size=0}) = 0
ioctl(1, TCGETS, {B38400 opost isig icanon echo ...}) = 0
getuid() = 1000
geteuid() = 1000
getgid() = 1000
getegid() = 1000
getuid() = 1000
geteuid() = 1000
getgid() = 1000
getegid() = 1000
stat("/home/dustin/.terminfo", 0x555be38c8ab0) = -1 ENOENT (No such file or directory)
stat("/etc/terminfo", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat("/lib/terminfo", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat("/usr/share/terminfo", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
access("/etc/terminfo/x/xterm-256color", R_OK) = -1 ENOENT (No such file or directory)
access("/lib/terminfo/x/xterm-256color", R_OK) = 0
openat(AT_FDCWD, "/lib/terminfo/x/xterm-256color", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=3503, ...}) = 0
read(3, "\36\2%\0&\0\17\0\235\1\356\5xterm-256color|xterm"..., 32768) = 3503
read(3, "", 28672) = 0
close(3) = 0
ioctl(1, TIOCGWINSZ, {ws_row=24, ws_col=194, ws_xpixel=0, ws_ypixel=0}) = 0
brk(0x555be38ef000) = 0x555be38ef000
ioctl(0, TIOCGWINSZ, {ws_row=24, ws_col=194, ws_xpixel=0, ws_ypixel=0}) = 0
brk(0x555be3910000) = 0x555be3910000
lstat("/opt/nxp", 0x7ffd41ec29a0) = -1 ENOENT (No such file or directory)
lstat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/share/gdb/auto-load", 0x7ffd41ec29a0) = -1 ENOENT (No such file or directory)
pipe([3, 4]) = 0
prlimit64(0, RLIMIT_NOFILE, NULL, {rlim_cur=1024, rlim_max=1024*1024}) = 0
mmap(NULL, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f1841681000
rt_sigprocmask(SIG_BLOCK, ~[], [], = 0
clone(child_stack=0x7f1841689ff0, flags=CLONE_VM|CLONE_VFORK|SIGCHLD) = 99522
munmap(0x7f1841681000, 36864) = 0
rt_sigprocmask(SIG_SETMASK, [], NULL, = 0
close(4) = 0
fcntl(3, F_GETFL) = 0 (flags O_RDONLY)
fstat(3, {st_mode=S_IFIFO|0600, st_size=0, ...}) = 0
read(3, "437//\n500//\n500V1//\n850//\n851//\n"..., 4096) = 4096
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=99522, si_uid=1000, si_status=0, si_utime=0, si_stime=0} ---
read(3, "DANISH//\nCSISO2022CN//\nCSISO2022"..., 4096) = 4096
read(3, "ISO-2022-CN//\nISO-2022-JP-2//\nIS"..., 4096) = 4096
read(3, "F10010001//\nOSF10010004//\nOSF100"..., 4096) = 1298
read(3, "", 4096) = 0
wait4(99522, [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 99522
close(3) = 0
prlimit64(0, RLIMIT_CORE, NULL, {rlim_cur=0, rlim_max=RLIM64_INFINITY}) = 0
brk(0x555be3931000) = 0x555be3931000
stat("/usr/local/NXP/S32DS.3.6.0/S32DS/tools/gdb-arm/arm32-eabi/bin/../lib/gdb", 0x7ffd41ec2a80) = -1 ENOENT (No such file or directory)
lstat("/opt/nxp", 0x7ffd41ec1980) = -1 ENOENT (No such file or directory)
brk(0x555be3952000) = 0x555be3952000
brk(0x555be3973000) = 0x555be3973000
pipe2([3, 4], O_CLOEXEC) = 0
fcntl(3, F_GETFD) = 0x1 (flags FD_CLOEXEC)
fcntl(3, F_SETFD, FD_CLOEXEC) = 0
fcntl(3, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
fcntl(4, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
poll([{fd=3, events=POLLIN}], 1, 0) = 0 (Timeout)
brk(0x555be3994000) = 0x555be3994000
brk(0x555be39b5000) = 0x555be39b5000
fcntl(0, F_GETFL) = 0x2 (flags O_RDWR)
ioctl(0, TIOCGPGRP, [99518]) = 0
pipe2([5, 6], O_CLOEXEC) = 0
fcntl(5, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
fcntl(6, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
poll([{fd=5, events=POLLIN}], 1, 0) = 0 (Timeout)
pipe2([7, 8], O_CLOEXEC) = 0
fcntl(7, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
fcntl(8, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
rt_sigaction(SIGINT, {sa_handler=0x555bda9b6dd0, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGTERM, {sa_handler=0x555bda8bd8a0, sa_mask=[TERM], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGQUIT, {sa_handler=0x555bda8bd780, sa_mask=[QUIT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGHUP, {sa_handler=0x555bda8bd750, sa_mask=[HUP], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGFPE, {sa_handler=0x555bda8bd9d0, sa_mask=[FPE], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGBUS, {sa_handler=0x555bda8bd9d0, sa_mask=[BUS], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGABRT, {sa_handler=0x555bda8bd9d0, sa_mask=[ABRT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGSEGV, {sa_handler=0x555bda8bdac0, sa_mask=[], sa_flags=SA_RESTORER|SA_ONSTACK, sa_restorer=0x7f18415fb420}, NULL, = 0
stat("/home/dustin/.config/gdb/gdbearlyinit", 0x7ffd41ec30a0) = -1 ENOENT (No such file or directory)
stat("/home/dustin/.gdbearlyinit", 0x7ffd41ec30a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/devices/system/cpu/online", O_RDONLY|O_CLOEXEC) = 9
read(9, "0-7\n", 8192) = 4
close(9) = 0
rt_sigprocmask(SIG_BLOCK, [INT ALRM TERM CHLD WINCH], [], = 0
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f1840324000
mprotect(0x7f1840325000, 8388608, PROT_READ|PROT_WRITE) = 0
clone(child_stack=0x7f1840b23870, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[99523], tls=0x7f1840b24700, child_tidptr=0x7f1840b249d0) = 99523
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f183fb23000
mprotect(0x7f183fb24000, 8388608, PROT_READ|PROT_WRITE) = 0
clone(child_stack=0x7f1840322870, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[99524], tls=0x7f1840323700, child_tidptr=0x7f18403239d0) = 99524
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f183f322000
mprotect(0x7f183f323000, 8388608, PROT_READ|PROT_WRITE) = 0
clone(child_stack=0x7f183fb21870, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[99525], tls=0x7f183fb22700, child_tidptr=0x7f183fb229d0) = 99525
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f183eb21000
mprotect(0x7f183eb22000, 8388608, PROT_READ|PROT_WRITE) = 0
clone(child_stack=0x7f183f320870, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[99526], tls=0x7f183f321700, child_tidptr=0x7f183f3219d0) = 99526
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f183e320000
mprotect(0x7f183e321000, 8388608, PROT_READ|PROT_WRITE) = 0
clone(child_stack=0x7f183eb1f870, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[99527], tls=0x7f183eb20700, child_tidptr=0x7f183eb209d0) = 99527
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f183db1f000
mprotect(0x7f183db20000, 8388608, PROT_READ|PROT_WRITE) = 0
clone(child_stack=0x7f183e31e870, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[99528], tls=0x7f183e31f700, child_tidptr=0x7f183e31f9d0) = 99528
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f183d31e000
mprotect(0x7f183d31f000, 8388608, PROT_READ|PROT_WRITE) = 0
clone(child_stack=0x7f183db1d870, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[99529], tls=0x7f183db1e700, child_tidptr=0x7f183db1e9d0) = 99529
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f183cb1d000
mprotect(0x7f183cb1e000, 8388608, PROT_READ|PROT_WRITE) = 0
clone(child_stack=0x7f183d31c870, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[99530], tls=0x7f183d31d700, child_tidptr=0x7f183d31d9d0) = 99530
futex(0x555be38c34b8, FUTEX_WAKE_PRIVATE, 1) = 1
rt_sigaction(SIGINT, {sa_handler=SIG_DFL, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, {sa_handler=0x555bda9b6dd0, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache", O_RDONLY) = 9
fstat(9, {st_mode=S_IFREG|0644, st_size=27002, ...}) = 0
mmap(NULL, 27002, PROT_READ, MAP_SHARED, 9, 0) = 0x7f1841683000
close(9) = 0
futex(0x7f1841289954, FUTEX_WAKE_PRIVATE, 2147483647) = 0
readlink("/usr/local/bin/python", 0x7ffd41ebda70, 4096) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/local/bin/pyvenv.cfg", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/local/pyvenv.cfg", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/local/bin/Modules/Setup.local", 0x7ffd41ebea10) = -1 ENOENT (No such file or directory)
stat("/usr/local/bin/lib/python3.10/os.py", 0x7ffd41ebe900) = -1 ENOENT (No such file or directory)
stat("/usr/local/bin/lib/python3.10/os.pyc", 0x7ffd41ebe900) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/python3.10/os.py", 0x7ffd41ebe900) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/python3.10/os.pyc", 0x7ffd41ebe900) = -1 ENOENT (No such file or directory)
stat("/usr/lib/python3.10/os.py", 0x7ffd41ebe900) = -1 ENOENT (No such file or directory)
stat("/usr/lib/python3.10/os.pyc", 0x7ffd41ebe900) = -1 ENOENT (No such file or directory)
write(2, "Could not find platform independ"..., 55Could not find platform independent libraries <prefix>
) = 55
openat(AT_FDCWD, "/usr/local/bin/pybuilddir.txt", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/local/bin/lib/python3.10/lib-dynload", 0x7ffd41ebda00) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/python3.10/lib-dynload", 0x7ffd41ebda00) = -1 ENOENT (No such file or directory)
stat("/usr/lib/python3.10/lib-dynload", 0x7ffd41ebda00) = -1 ENOENT (No such file or directory)
write(2, "Could not find platform dependen"..., 58Could not find platform dependent libraries <exec_prefix>
) = 58
write(2, "Consider setting $PYTHONHOME to "..., 57Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
) = 57
getrandom("\x04\xf0\xa2\x12\x5c\x58\x69\xf9\xe7\x92\x2a\xc4\x9b\x55\x5c\xfc\x1f\x56\x13\xd5\x39\xe0\xe5\x4e", 24, GRND_NONBLOCK) = 24
brk(0x555be39eb000) = 0x555be39eb000
mmap(NULL, 1048576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f183ca1d000
brk(0x555be3a13000) = 0x555be3a13000
mmap(NULL, 1048576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f183c91d000
sysinfo({uptime=4102, loads=[17216, 11392, 7168], totalram=4100464640, freeram=251756544, sharedram=39157760, bufferram=148140032, totalswap=1713590272, freeswap=1447161856, procs=577, totalhigh=0, freehigh=0, mem_unit=1}) = 0
openat(AT_FDCWD, "/etc/localtime", O_RDONLY|O_CLOEXEC) = 9
fstat(9, {st_mode=S_IFREG|0644, st_size=3592, ...}) = 0
read(9, "TZif2\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\10\0\0\0\10\0\0\0\0"..., 4096) = 3592
lseek(9, -2280, SEEK_CUR) = 1312
read(9, "TZif2\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\10\0\0\0\10\0\0\0\0"..., 4096) = 2280
brk(0x555be3a34000) = 0x555be3a34000
close(9) = 0
stat("/usr/local/lib/python310.zip", 0x7ffd41ec1290) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale/locale.alias", O_RDONLY|O_CLOEXEC) = 9
fstat(9, {st_mode=S_IFREG|0644, st_size=2996, ...}) = 0
read(9, "# Locale name alias data base.\n#"..., 4096) = 2996
read(9, "", 4096) = 0
close(9) = 0
openat(AT_FDCWD, "/usr/share/locale/en_US.UTF-8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale/en_US.utf8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale/en_US/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale/en.UTF-8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale/en.utf8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale/en/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale-langpack/en_US.UTF-8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale-langpack/en_US.utf8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale-langpack/en_US/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale-langpack/en.UTF-8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale-langpack/en.utf8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale-langpack/en/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/python310.zip", 0x7ffd41ec1070) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/python3.10", 0x7ffd41ec1290) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/python3.10", 0x7ffd41ec1070) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/lib-dynload", 0x7ffd41ec1290) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/lib-dynload", 0x7ffd41ec1070) = -1 ENOENT (No such file or directory)
write(2, "Python path configuration:\n", 27Python path configuration:
) = 27
write(2, " PYTHONHOME = ", 15 PYTHONHOME = ) = 15
write(2, "(not set)", 9(not set)) = 9
write(2, "\n", 1
) = 1
write(2, " PYTHONPATH = ", 15 PYTHONPATH = ) = 15
write(2, "\n", 1
) = 1
write(2, " program name = ", 17 program name = ) = 17
write(2, "'", 1') = 1
write(2, "/", 1/) = 1
write(2, "u", 1u) = 1
write(2, "s", 1s) = 1
write(2, "r", 1r) = 1
write(2, "l", 1l) = 1
write(2, "o", 1o) = 1
write(2, "c", 1c) = 1
write(2, "a", 1a) = 1
write(2, "b", 1b) = 1
write(2, "i", 1i) = 1
write(2, "n", 1n) = 1
write(2, "p", 1p) = 1
write(2, "y", 1y) = 1
write(2, "t", 1t) = 1
write(2, "h", 1h) = 1
write(2, "\n", 1
) = 1
write(2, " isolated = 0\n", 15 isolated = 0
) = 15
write(2, " environment = 1\n", 18 environment = 1
) = 18
write(2, " user site = 1\n", 16 user site = 1
) = 16
write(2, " import site = 1\n", 18 import site = 1
) = 18
write(2, " sys._base_executable = ", 25 sys._base_executable = ) = 25
write(2, "'/usr/local/bin/python'", 23'/usr/local/bin/python') = 23
write(2, "\n", 1
) = 1
write(2, " sys.base_prefix = ", 20 sys.base_prefix = ) = 20
write(2, "'/usr/local'", 12'/usr/local') = 12
write(2, "\n", 1
) = 1
write(2, " sys.base_exec_prefix = ", 25 sys.base_exec_prefix = ) = 25
write(2, "\n", 1
) = 1
write(2, " sys.platlibdir = ", 19 sys.platlibdir = ) = 19
write(2, "'lib'", 5'lib') = 5
write(2, "\n", 1
) = 1
write(2, " sys.executable = ", 19 sys.executable = ) = 19
write(2, "\n", 1
) = 1
write(2, " sys.prefix = ", 15 sys.prefix = ) = 15
write(2, "\n", 1
) = 1
write(2, " sys.exec_prefix = ", 20 sys.exec_prefix = ) = 20
write(2, "\n", 1
) = 1
write(2, " sys.path = [\n", 15 sys.path = [
) = 15
write(2, " '/usr/local/lib/python310.zi"..., 36 '/usr/local/lib/python310.zip',
) = 36
write(2, " '/usr/local/lib/python3.10',"..., 33 '/usr/local/lib/python3.10',
) = 33
write(2, " '/usr/local/lib/lib-dynload'"..., 34 '/usr/local/lib/lib-dynload',
) = 34
write(2, " ]\n", 4 ]
) = 4
ioctl(2, TCGETS, 0x7ffd41ec2a60) = -1 ENOTTY (Inappropriate ioctl for device)
write(2, "Python Exception ", 17Python Exception ) = 17
write(2, "<class 'ModuleNotFoundError'>", 29<class 'ModuleNotFoundError'>) = 29
write(2, ": ", 2: ) = 2
write(2, "No module named 'encodings'", 27No module named 'encodings') = 27
write(2, "\n", 1
) = 1
futex(0x7f18412a81e0, FUTEX_WAKE_PRIVATE, 2147483647) = 0
rt_sigaction(SIGINT, {sa_handler=0x555bda9b6dd0, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, {sa_handler=SIG_DFL, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f18410df090}, = 0
sigaltstack({ss_sp=NULL, ss_flags=SS_DISABLE, ss_size=0}, NULL) = 0
rt_sigprocmask(SIG_BLOCK, [TTOU], [], = 0
ioctl(1, TCSBRK, 1) = 0
rt_sigprocmask(SIG_UNBLOCK, [TTOU], NULL, = 0
write(2, "Python not initialized", 22Python not initialized) = 22
ioctl(2, TCGETS, 0x7ffd41ec3040) = -1 ENOTTY (Inappropriate ioctl for device)
write(2, "\n", 1
) = 1
exit_group(1) = ?
+++ exited with 1 +++
