Turn on the "Path, Location of error " in S32DS
1,732 次查看
tuanhoc8
Hello everyone, I have a problem and need help:
I lost Location and Path of error when building project. How to turn on it?
I'll appreciate any help.
Cheers,
Tuan.
1,653 次查看
jiri_kral
you are probably mixing two Autosar versions as is written in the first #error message. It is possible share your project?
5 回复数
1,706 次查看
tuanhoc8
@jiri_kral
 This is my "Problem view". when i double click on the error, I can't go to the error line. However, on the S32DS of my friend, the double will bring to the line of the error.
1,654 次查看
jiri_kral
1,576 次查看
tuanhoc8
@jiri_kral Sorry, I have just recieved a message from Gmail today.
Tks you again for taking a time for my project. I have fixed it tks you too much
1,711 次查看
jiri_kral
can you please share the output from build console?
1,694 次查看
tuanhoc8
@jiri_kral
This is the "Problem view" of my friend.
After build the path and location of error  appear and he just click on it, the line of the error is selected. However, my S32DS doesn't have the path and location of error after build.
