How to set signal(s) back to "No pin routed" after "accidentally" setting them to some specific pin(s)?
I routed some signals to specific pins. I wanted to set them back to "No pin routed" but I could only set these signals to other pins within a list but not back to "No pin routed".
I am using S32K148 100 LQFP on S32 Design Studio for Arm.
See attached file with a screen-shot.
Solved! Go to Solution.
Hi hw,
You can select "Pins" in View Mode, and uncheck the selected function.
Then it will back to "no pin routed".
Robin
Hi hw,
Robin
Thanks Robin.
