how to add Z 4_0core、Z4_1core project on the Z2 single core project ? Single-core(Z2) engineering was used for early development,Now i want to add two more cores(Z4),Is there a specific operation method?
Solved! Go to Solution.
Hello LongFei,
in my opinion it is easier to create a new multicore project using S32DS New Project Wizard and transfer all the Z2 core source code / settings into the new project. The multicore project composes from 3 projects per core.
This way you will have fully functional multicore project with Debug configuration that allows multicore debugging.
Hope it helps.
Stan
Hello LongFei,
Hope it helps.
Stan
THKS problem has been solved
