SDK required although I installed the latest version of SDK
2,456 次查看
abderrahimjamao
Hello, I have a problem when I try to install an existing project.
标记 (3)
2,367 次查看
jiri_kral
S32DS for ARM v2.2 doesn't support older SDK versions. You can use older S32DS ARM  v2018.R1 - https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=S32-DS-ARM_v2018
Hope it helps.
Jiri
2,367 次查看
abderrahimjamao
Yes, I do it thanks.
