S32K148 measure frequencies less than 1hz
piotr3332
I would like to know how to use the FTM to measure frequencies lower than 1Hz?
Robin_Shen
Hi piotr3332,
Please refer the ftm_signal_measurement_s32k148. If the FTM overflow too frequency, then you may need to add a software count in overflow interrupt.
Robin
