when i debug HSE on S32G3 with HSE_DEMOAPP_S32G3XX_0_2_16_1/demo_app , every times i loads "HSE_DEMO_S32G3XX_BuildConfig_Flash_Load_Symbols " throuth S32 Debug Probe, once i clicked then Suspend(||) button on the toobar to pause the application execution, and then there's error
(failure during exectuion of python script / failed to execute MI command, )
how can i solved this problem ?
thinks
Are you using any NXP reference board? Are you able to run the HSE_DEMOAPP (no debug)? Can you see the terminal print the information shown (or similar to it) under the HSE_DEMOAPP?
How did you build the HSE_DEMOAPP? If you could detail the steps, it will be better for our understanding.
Please, let us know.
Hi, Daniel-Aguirre:
thinks for your replay, I'm using my own product board and demo-app works fine.
i have terminal print but i don't know why i can't upload a screenshot, brief description below:
1. boot configuration is from qspi, gZero==0,
Thanks for your feedback. We understand that the HSE_DEMOAPP was flashed correctly (since the message is shown under the terminal).
We seem to be able to reproduce the outcome you are seeing. We will investigate this matter and update you as soon as we can. We apologize for the delay.
We have received the following update:
"Please make sure that they use S32DS 3.5 for G3_HSE_DEMO project debugging. It seems they still use S32DS 3.4 for this project debugging."
Thanks for your feedback. We will continue looking into this.
We apologize for any delay from our side.
It may be caused by the debugging port being closed. Please delete the command shown below and rebuild.
Thinks for you replay, I'm so sorry to tell you ,When I comment the function"SystemWfiConfig" in line 550 of the file system.c according to what you said and then debugging with attach,But It still reported an same error as before. Did i misunderstand what you said about "delete the command shown below and rebuild" ? If so ,how should I solve this problem correctly ?
Looking forward to you replay! thinks
Thanks for your feedback. Looking through the HSE_DEMOAPP_0_2_16_1 Read me, we see the following information is shown [Page 11]:
Which seems contrary to what the internal team mentioned. Still, we tried with those specific versions and we are able to debug the application correctly:
Once thing is that we first need to select the "S32Debug" configuration. This will fail, then we select the "Load_Symbols" configuration, then we are able to debug no problem:
We see the following outcome on our console:
In which, until the 3rd print, we see that the debugger was set as active, then we are able to continue no problem.
Again, we apologize for the inconvenience this may cause.
