S32G2 : MCU is not supported
已解决
跳至解决方案
6,671 次查看
yonghwi_lee
Hi Team,
Our custoemr, HL Mando, has reported that S32DS shows "MCU is not supported" and customer can not generate source code by Configuration Tool.
Customer installed below packages
S32DS.3.4_b201217_win32.x86_64.exe
SW32G_S32DS_3.4.3_D2112.zip
SW32G_RTD_4.4_3.0.2_HF01_DS_updatesite_D2204.zip
SW32G_IPCF_4.6.0_D2205_updatesite.zip
Could let me know why this error shows and how to solve this issue?
Yonghwi Lee
标签 (2)
1 解答
6,473 次查看
yonghwi_lee
Hi Mehul,
Customer found the solution after investigating ".metadata\.log ".
The log showed "Could not parse file 'C:\NXP\S32DS.3.4_1\eclipse\mcu_data\processors\S32G274A_Rev2\PlatformSDK_S32XX_2022_03\clocks\S32V2xx.dsn" and S32V2xx.dsn was encrypted via DRM.
The customer security program prevented S32V2xx.dsn from parsing. Some security rules were changed in customer site and problem solved.
Thanks for your supports.
Yonghwi Lee
在原帖中查看解决方案
9 回复数
6,017 次查看
Mehul_Patel_NXP
@Changwoo82 ,
Thank you for comment on the issue.
Happy coding.
- Mehul Patel
6,504 次查看
Mehul_Patel_NXP
Hi, @yonghwi_lee ,
Sorry for the late reply,
Please can you ask customer to send workspace log from
C:\Users\Public\[Workspace]\.metadata to help if there is any error. (or wherever the particular workspace is located from that workspace log)
Thank you.
- Mehul
6,514 次查看
Mehul_Patel_NXP
Hi, @yonghwi_lee ,
Sorry for the late reply.
Please can you ask the customer for the workspace log, which should be available at
C:\Users\Public\[Workspace name]\.metadata
Thank you, Best regards,
- Mehul Patel
6,474 次查看
yonghwi_lee
Hi Mehul,
Yonghwi Lee
6,510 次查看
yonghwi_lee
Hi Mehul,
Project shows below errors.
An error has occurred. See error log for more details.
PeripheralExpressionException[
Description: Could not parse string argument: "" to rational number
Function: toInt(valid)
Contexts:
ExpressionContext[ child_context = ChildContext[
$this = Mcu.McuModuleConfiguration.McuClockSettingConfig.0.McuRtcClockSelect.McuRtc_Source
$instance = Mcu
$group = BOARD_InitPeripherals]]
$instance = Mcu
$instance = Mcu
$instance = Mcu
I will ask for customer to get metadata.
Yonghwi Lee
6,641 次查看
Mehul_Patel_NXP
Hi, @yonghwi_lee ,
Please can you get more information from the customer to understand the issue.
Or, please can you suggest the customer to use S32DS3.5 and the latest package for S32G2 required for it.
Thank you, Kind regards.
- Mehul
6,545 次查看
yonghwi_lee
Hi Mehul,
The customer installed security program on windows. I think this issue is casued by security program.
The customer needs to solve this issue to use S32D2 and asked what could be causing this issue and how to get error logs.
Could you let me know the details of the error "MCU is not supported"?
Yonghwi Lee
6,581 次查看
yonghwi_lee
Hi Mehul,
The customer alreday installed the latest package for S32G2 and it still shows same error "MCU is not supported". I did test S32G2 package and I can't reproduce this issue.
Could you let me know what could be causing this issue and is there something to get error logs?
Yonghwi Lee
6,089 次查看
Changwoo82
I believe the issue has already been resolved, but I wanted to leave this comment here.
I encountered the same problem, and it was resolved after decrypting the file 'S32V2xx.dsn.
