S32DS for ARM version 3.6.0 IAR plugin install failing to install
469 次查看
caio_electrontransport
Hello
I am trying to install the IAR plugin for S32DS and it is failing. When I reach the following point it fails: (finish)
Error Message:
An error occurred while collecting items to be installed
session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,javaewah,1.1.6.v20160919-1400
No repository found containing: osgi.bundle,org.apache.commons.compress,1.6.0.v201310281400
Could you please help me?
C.
399 次查看
jiri_kral
are you using this repository for IAR plugin manager? https://eclipse-update.iar.com/plugin-manager/1.0  ?
I tested it right now and it works.
