Hello team,
My customer reported the import & build issue for the S32DS for ARM v2.2.
They tried to import the project which they received from their customer, and faced the issue that the progress was pending at the compiler built-in language setting.
So they stopped this setting and then the import was done. However, when they tried to build it, the build process was pending at below.
Would you please give me some advice for the potential root cause and what I should check further?
James
Hi James,
it is first time when I'm seeing such issue. It is possible share customer's project - for example via NXP email?
Jiri
Hi Jiri,
Thanks for your answer, but customer couldn't share their project because of their s/w security policy.
I shared your answer that we never seen this kind of issue, and let you know if I have further update from customer.
James
