S32DS for ARM 2018R1 license
binli
Hi:
My license of S32DS for ARM 2018R1 IDE has expired. Could you help check and extend it for me?
Thanks.
mikedoidge
I've extended your entitlement. Please refresh or re-activate your installation.
Mike
valeriaalessi
Good morning,
I tried to re-activate with the same license number but it continues to tell me that the license is for another feature. However, the second error about exceeded number of returns does not come out again, after the first one.
Could you help me?
Thanks a lot.
Valeria
mikedoidge
Hello @valeriaalessi,
I have manually returned the license from the server side. When you receive the offer to return the license, please choose 'Yes'. Sometimes there is some setting which does not get reset properly and this will force it to be reset. After this, and with my action to return the license, you should be able to activate without issue.
Mike
valeriaalessi
Good morning!
The issue is solved!
Thanks a lot.
Valeria
mikedoidge
I have extended your license through 2025. Please refresh from the Help->NXP Licenses menu or reactivate using the same activation code as before.
Mike
valeriaalessi
Good morning,
I tried to activate again the license, with the same number as before, but it tells me that the license is for another feature. Then, if I click on return, a error message appears (see attachments).
Could you help me please?
Thanks a lot!
mikedoidge
Mike
e-look_see
Hi, My S32 Design Studio for ARM v2018 R1 License has already expired,could you help to extend it?Thanks! Activation Code: 3EF3-981A-CE8D-45C3
KerwinCao
Hello, my license of S32 Design Studio for ARM Version 2018.R1 expiration soon
Could you please extend it ? Thanks.
My activation Code: C617-86A4-65B7-F3D9
Thanks a lot
Xuchengcheng
My activation Code: 516A-3379-0522-6A9D
Thanks a lot
csuiil
Hi:
Thanks.
Item DescriptionS32 Design Studio
Order NumberS32DS_2018_R1_100931407
Purchase Order Number
Total Number of Licenses:100
Activation Code  C625-7579-0C28-63DC
License Applicable to Product(s):
Version Description
R1 2018 S32 Design Studio (View EULA) 3.1 S32 Design Studio (View EULA)
100 Available
HoganLiu
Dear,
my license of S32 Design Studio for ARM Version 2018.R1 has expired. Could you please extend it for me?
Activation Code: E03E-A0CC-D45D-88C8
Thanks a lot
liamtsen
Hi, my licence is expired, can you help me to extend it?
The number is
Thanks a lot.
Mehul_Patel_NXP
Hi, @liamtsen ,
I have extended your license through end of December 2028.
Please refresh the activation to use it.
Thank you. Best regards.
- Mehul Patel
w_lingjun
My S32 Design Studio for ARM v2018.R1 License has already expired. Could you please help to extend it? Thanks!
Activation Code: B7B1-173F-51BA-13A2
Sarah
mikedoidge
Hi Sarah,
Your license has been extended, please try the activation code again.
Mike
th_China
My S32 Design Studio for ARM 2018_R1 would expired in 4 days, could you help to extend it? thanks;
ActivationId: 799E-5E79-910F-6C57
mikedoidge
Hello Hao,
I have extended your license by 3 years. Please go to the Help -> NXP License menu in S32DS and click "Refresh" to update the license data on your local machine.
Mike
1772137309
Activation Code: B0A4-688C-2AD6-79EE
Mehul_Patel_NXP
Hi, @1772137309 .
I have extended your license through end of 2028.
- Mehul Patel
zhanglei327
My license will be expired soon.
mikedoidge
Hello @zhanglei327,
I have extended your entitlement through 2025. Please use the 'Refresh' button located within the Help -> NXP Licenses menu to synchronize your installation with the license server.
Mike
