Hi:
My license of S32DS for ARM 2018R1 IDE has expired. Could you help check and extend it for me?
Thanks.
Solved! Go to Solution.
I've extended your entitlement. Please refresh or re-activate your installation.
Mike
Hi, @J_Gary ,
I have extended your license expiration to end of 2028.
Please use the 'Refresh' action in the NXP License menu to update your local license info.
Mehul
thanks
Hi:
My license ofS32DS_Power_Win32_v2.1 IDE has expired. Could you help check and extend it for me?
Thanks.
My S32 Design Studio for ARM v2018 R1 License has already expired,could you help to extend it?Thanks!
Activation Code: 6C82-9208-D1F2-C38F
Hi, @ScreenUser ,
I have extended your license expiration to 2027.
- Mehul Patel
Hello, My license expired now, please help to extended license , active code :93E3-80E7-2A38-9E70
Hi, @Hansheng ,
I have extended your license through end of 2027. Please refresh the activation to use it.
Thank you. Best regards.
-Mehul Patel
Good morning,
my license of S32 Design Studio for Power Architecture Version 2.1 IDE has expired. Could you please extend it for me?
Activation Code DBA1-317C-5265-7E4F
Thanks a lot.
Hello NXP expert,
My S32DS for Arm v2018 license has expired, the license has been returned and it shows the license is missing by now, please help to extend the license, thanks a lot !
David
Hi, @zuqiao ,
Please can you share the activation code for the S32DS for Arm v2018, so that I can reactivate your license.
-Mehul Patel
The activation code is D876-C313-75B1-2E1B , thanks.
Hi, @zuqiao ,
I have extended your license through end of December - 2026.
Please refresh the activation.
Thank you. Kind regards.
- Mehul Patel
Hi, Mehul_Patel,
S32DS works now, thank you very much !!!
Hi, my licence is expired, can you help me to extend it?
The number is
Thank you.
Francesco
I have extended your license through 2025. Please re-activate with the same code.
Mike
My license has also expired (9DE8-C6AE-8B6B-952B), could you extend it for me? Thank you very much!
Hi, @cjgyf ,
I've extended your entitlement through end of December 2025. Please refresh or re-activate your installation.
- Mehul Patel
