[S32DS for ARM 2018.R1] How to download separate s-record file into the S32K146
1,412件の閲覧回数
james-lee
I'm using the S32DS for ARM 2018.R1 and could not download the s-record file to the S32K146.
I saw the guide at the post below, and tried to follow all three cases. However, I couldn't do it with the 1st way and 2nd way.
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-download-separate-elf-srec-hex-f...
Would you please review the failure message attached, and let me know what the problem is?
James
1,400件の閲覧回数
jiri_kral
actually the only difference between .flashing srec and .elf files is selecting .srec instead of .elf file in debug configurations:
There are no additional special steps. The - s-record file is not an executable file (in meaning what is .elf or  .exe format)  - it is content of memory represented by text file format.
