S32DS Resource '/USEBSPLIB/GetAutoAlignmentInfo.args' does not exist
694 次查看
deft
After the project is modified on the original project, there is a problem in the compilation. It shows that the .args resource does not exist. Indeed, there is no corresponding .args file (Q0.png) under /USEBSPLIB, and the original project will be compiled under /USEBSPLIB. The corresponding .args file (Q1 .png) and sometimes the makefile or sources.mk file does not exist
454 次查看
Mehul_Patel_NXP
Hi, @deft ,
Please let us know if you were able to solve the issue.
This thread may help for the issue.
https://stackoverflow.com/questions/48478409/getting-an-error-that-package-does-not-exist-in-eclipse...
Thank you. Best regards.
-Mehul Patel
