S32DS 2.1 How to extend license
1,106件の閲覧回数
kuhruhm
How to extend(or renew) the S32DS license? I tried to re-install it. but I was halted on licensing.
1,051件の閲覧回数
Mehul_Patel_NXP
Hi, @kuhruhm ,
I see the problem was because the older licenses was not returned.
It should be fixed now.
Please can you try installing now using the license.
Thank you. Best regards.
-Mehul Patel
6 返答(返信)
1,096件の閲覧回数
kuhruhm
My S32DS is version 2.1
I tried to install it on a new computer.
Halted online licensing and I did stop by the task manager.
c:\NXP\S32DS_Power_v2.1\_S32 Design Studio for Power Architecture Version 2.1_installation\Logs\
Has no file.
1,088件の閲覧回数
Mehul_Patel_NXP
Hi, @kuhruhm ,
As I see in the below error in your log I think the issue is because of not running as administrator mode or not having enough permission while installation.
Your Windows user account must be a member of the administrator's group as mentioned in installation guide. https://www.nxp.com/docs/en/user-guide/S32DSPAIG.pdf
The 'Run as Administrator' option should not be used for the installation of the S32 Design Studio. If you are getting an error on Windows permissions, then you likely do not have the necessary permissions to install.
If you have issue to run as administrator mode please contact your IT department to for their assistance.
Please let us know if you are able to move further.
- Mehul Patel
1,061件の閲覧回数
kuhruhm
I retried as an administrator. but nothing changed.
but halted online licensing, and no log was created.
My license exp. is Oct 1, 2023
Entitlement Exp is Oct 3, 2027
Does this mean my license is active?
1,052件の閲覧回数
Mehul_Patel_NXP
Hi, @kuhruhm ,
-Mehul Patel
1,046件の閲覧回数
kuhruhm
Yes, It works.
But when I clicked the return button, that did not work.
Problem solved, installation succeed.
Thank you.
1,103件の閲覧回数
Mehul_Patel_NXP
Hi, @kuhruhm ,
Please can you share the S32DS installation log from the :
C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\Logs
Thank you.
Best regards.
- Mehul Patel
