S32DS 2.0 for ARM Export to IAR project
mikeshin
Greetings,
I am using S32DS 2.0 for ARM on S32K144 projects and would like to use IAR to do the compile and debug.
When I tried to Export, "Export Error" was occurred as attached image.
How I can generate the projectinfo.xml file?
Mike Shin
stanish
Hello Mike,
Thanks indeed for this report!
I'm able to reproduce the issue and I'm pretty confident this is a Project Exporter defect. Our development team is currently checking this.
Stan
