S32 design studio for power architecture version 2017.r1 compiler optimization level O1, what specif
已解决
跳至解决方案
2,428 次查看
StarMao159376
Hi,Sir, S32 design studio for power architecture version 2017.r1 compiler optimization level O1, what specific optimization has been done, and can optimization be enabled?
Found in the actual project: 1 For the same 200m main frequency, mpc5744 takes more than twice as long as tc275!!!
2. However, when the optimization above O1 is enabled, the operation efficiency is significantly improved
1 解答
2,409 次查看
jiri_kral
s32ds uses gcc compiler - the optimization level description you can find here:
https://gcc.gnu.org/onlinedocs/gcc/Optimize-Options.html
Jiri
在原帖中查看解决方案
2 回复数
2,410 次查看
jiri_kral
Jiri
2,389 次查看
StarMao159376
Thanks.
