S32 Design Studio for Arm expiring in 22 days
849 次查看
fabriziotorrero
S32 Design Studio for ARM license expiring in 22 days,how can i solve it?Thanks!
ActivationId: E284-09C9-3CDF-3E69
Evaluation Days: 22
Feature Version: 2.2
Feature Status: Evaluation (22 days)
12 回复数
812 次查看
jiri_kral
your S32DS license has been extended. Please activate S32DS again with your old code.
804 次查看
fabriziotorrero
How can I activate S32DS again with my old code? (S32DS is already installed)
786 次查看
jiri_kral
you can left the license expire or return it. On main menu bar Help -> NXP Licenses -> Open -> Return License.
774 次查看
fabriziotorrero
I have already tried but this message appears
743 次查看
jiri_kral
I suggest to left the license expire automatically. I already returned licenses from your account, the license record is stored in local trusted storage in your PC.
If you like to remove local license - make backup of c:\ProgramData\FLEXnet\ (the folder is hidden by default) and delete content of that folder.
732 次查看
fabriziotorrero
now it's OK!
I have a similar problem with the S32DS_ARM_v2018.R1 with the license 3C5C-8F28-2B07-3102 (see image below).
Is it possible to restore it?
719 次查看
jiri_kral
License has been extended.
713 次查看
fabriziotorrero
I tried to insert the license, but the result is always the error indicated in the previous image.
706 次查看
jiri_kral
Looks that you are using activation key from your colleague (no problem). I extended S32DS license for Dario as well.
657 次查看
fabriziotorrero
Thank you very much!
Sorry but for S32DS_ARM_v2018.R1 I still have the problem that it does not work (always the same error message appears). Is it because the license is already expired?
831 次查看
petervlna
You can simply download S32DS for Arm here:
https://www.nxp.com/design/design-center/software/automotive-software-and-tools/s32-design-studio-id...
Or you can use S32DS for S32DS for S32 Platform for S32K1 which is even better:
Peter
368 次查看
francescovico
Hello I have the same problem with :
S32 Design Studio for ARM Version 2018.R1
My Software Activation Code is:
EEB7-4F1A-CAD1-B40E
Can you extend my license?
Regards, Francesco.
