S32 Design Studio for ARM license expiring in 13 days,how can i solve it?Thanks!
ActivationId: F625-BD17-9FB6-009D
Evaluation Days: 13
Feature Version: 2.2
Feature Status: Evaluation (13 days)
Solved! Go to Solution.
I have returned your license, when you re-activate, the new expiration date will be loaded.
Mike
Sorry, I have the same issue for
S32 Design Studio for ARM v2018 R1
Activation code: E281-F80C-438F-6887
Please, could you renew also it.
This one has been renewed through 2025. Please re-activate your installation.
Mike
Hi NXP-Team,
my license has expired too. Can you please help me with that?
Markus
Hello Markus,
I have extended your entitlement through 2025. Please re-activate your installation.
Mike
Hi, I have the same issue:
Fulfillment ID: 153510107
Expiration Date: Aug 1, 2022
Product: S32 Design Studio for ARM v2018 R1
Machine: 70990A1E3F1FE8C48BAD3BAF14F6163E9DA45CDC
Activation Code: CE54-8A45-DFCB-2A14
Hi Jonas,
I have extended your entitlement. Since your license has already expired, you probably won't be able to refresh. You will need to re-activate using the existing activation code. It should prompt you when you launch S32 Design Studio.
Mike
Hi my license is expired too. Can you extend it? thank you!
S32 Design Studio for PA E200 v2.0
4A7F-2866-9BBB-431E
It needs NXP Employee to extend.
Your license was extended through 2025.
Please refresh or reactivate your license.
Mike
Same problem here, license expired, cant renew the license.
ActivationID: D70F-D40C-4AD2-DF97
Version 2018.R1
Can somebody help me with this?
Hello Artur,
I have extended your entitlement through 2025. Please refresh the license from within the Help->NXP Licenses menu. Or you might have to return and re-activate using same activation code as before.
Please let me know of any further issue.
Mike
I would like my license extended as well.
License Applicable to Product(s):
Version | Description | ||
2018 | S32 Design Studio for ARM v2018 R1 |
1 |
194470497 |
Jun 4, 2022 |
Activation Code:
CCF8-7C0D-1FEF-C281 |
I extended your license till end of 2025. Please enter your activation code in S32DS again.
Jiri
Hi Mike,
Kindly renew
Fulfillment ID: | 192400897 |
Expiration Date: | Mar 15, 2022 |
Product: | S32 Design Studio for ARM v2018 R1 |
Machine: | 6DB8562794A476A701EEF087DCDA7006DDF50E2C |
Activation Code: | 89AE-671C-7A13-D4D3 |
Your entitlement has been extended through 2025. Please either 'refresh' the license from the NXP Licenses menu (Help -> NXP Licenses) or re-activate using the code you shared.
Mike
Hi Mike,
My S32 Design Studio for Power architecture license expired (B86D-B7D4-0C1D-3021), can you please extend it?.
Hi Ramesh,
I have extended your entitlement through 2025. Please refresh the license or reactivate your install.
Mike
Hello
I have the same problem too.
Can you reactivate my license for S32 Design Studio for ARM V1.3, please?
Activation ID: 816A-E5D9-CA6E-E65E
Hi @Bryan9,
I've extended yours. Please try the Refresh option in the license menu of S32 Design Studio.
Mike
