S32 Design Studio for ARM license expiring in 13 days
33,525 次查看
609510318
S32 Design Studio for ARM license expiring in 13 days,how can i solve it?Thanks!
ActivationId: F625-BD17-9FB6-009D
Evaluation Days: 13
Feature Version: 2.2
Feature Status: Evaluation (13 days)
33,404 次查看
mikedoidge
I have returned your license, when you re-activate, the new expiration date will be loaded.
Mike
68 回复数
8,511 次查看
Romeo
Hi Mike,
I made the KEA8 firmware using S32 Design Studio for ARM v2.2 3 year free license.
The current project is over.
We are currently selling products with firmware (*.srec) created by the project.
When the license expires, will I be unable to sell products made with the current firmware?
romeo
8,492 次查看
mikedoidge
Hello Romeo,
I believe you are confusing the Software License Agreement with the Software Tools License.
The Software License Agreement covers how the software you develop using the NXP provided SDKs may be used and distributed. The terms and conditions you agreed to when you installed the SDK specify the limitations. I'm not aware there is a defined time limit, but you should review this agreement to ensure you understand the limitations and that you are in compliance.
The Software Tool License for S32 Design Studio is what enables you to activate and make use of the IDE for development purposes. You cannot use the IDE without an active license. This license is generally provided with expiration of 3 years, however, we can extend the tool license for you at any time.
I hope this answers your question.
Mike
9,619 次查看
Att1l10
Sorry, I have the same issue for
S32 Design Studio for ARM v2018 R1
Activation code: E281-F80C-438F-6887
Please, could you renew also it.
9,614 次查看
mikedoidge
This one has been renewed through 2025. Please re-activate your installation.
Mike
9,908 次查看
markus1
Hi NXP-Team,
my license has expired too. Can you please help me with that?
Markus
9,882 次查看
mikedoidge
Hello Markus,
I have extended your entitlement through 2025. Please re-activate your installation.
Mike
10,285 次查看
jonaspause
Hi, I have the same issue:
Fulfillment ID: 153510107
Expiration Date: Aug 1, 2022
Product: S32 Design Studio for ARM v2018 R1
Machine: 70990A1E3F1FE8C48BAD3BAF14F6163E9DA45CDC
Activation Code: CE54-8A45-DFCB-2A14
10,282 次查看
mikedoidge
Hi Jonas,
I have extended your entitlement. Since your license has already expired, you probably won't be able to refresh. You will need to re-activate using the existing activation code. It should prompt you when you launch S32 Design Studio.
Mike
10,850 次查看
renzoquaglieri
Hi my license is expired too. Can you extend it? thank you!
S32 Design Studio for PA E200 v2.0
4A7F-2866-9BBB-431E
10,822 次查看
chrislin_wpi
It needs NXP Employee to extend.
10,841 次查看
mikedoidge
Your license was extended through 2025.
Please refresh or reactivate your license.
Mike
11,132 次查看
ArturG
Same problem here, license expired, cant renew the license.
ActivationID: D70F-D40C-4AD2-DF97
Version 2018.R1
Can somebody help me with this?
@mikedoidge
11,128 次查看
mikedoidge
Hello Artur,
I have extended your entitlement through 2025. Please refresh the license from within the Help->NXP Licenses menu. Or you might have to return and re-activate using same activation code as before.
Please let me know of any further issue.
Mike
10,703 次查看
debangshudey
I would like my license extended as well.
License Applicable to Product(s):
  Version  Description
  2018  S32 Design Studio for ARM v2018 R1
1
194470497
Jun 4, 2022
Activation Code:
CCF8-7C0D-1FEF-C281
10,693 次查看
jiri_kral
I extended your license till end of 2025. Please enter your activation code in S32DS again.
Jiri
11,437 次查看
vlele
Hi Mike,
Kindly renew
Fulfillment ID:
192400897
Expiration Date:
Mar 15, 2022
Product:
Machine:
6DB8562794A476A701EEF087DCDA7006DDF50E2C
Activation Code:
89AE-671C-7A13-D4D3
11,419 次查看
mikedoidge
Your entitlement has been extended through 2025. Please either 'refresh' the license from the NXP Licenses menu (Help -> NXP Licenses) or re-activate using the code you shared.
Mike
11,589 次查看
Rameshv
Hi Mike,
My S32 Design Studio for Power architecture license expired (B86D-B7D4-0C1D-3021), can you please extend it?.
11,545 次查看
mikedoidge
Hi Ramesh,
I have extended your entitlement through 2025. Please refresh the license or reactivate your install.
Mike
12,851 次查看
Bryan9
Hello
I have the same problem too.
Can you reactivate my license for S32 Design Studio for ARM V1.3, please?
Activation ID: 816A-E5D9-CA6E-E65E
