S32 Design Studio for ARM license expiring in 13 days
35,880 次查看
609510318
S32 Design Studio for ARM license expiring in 13 days,how can i solve it?Thanks!
ActivationId: F625-BD17-9FB6-009D
Evaluation Days: 13
Feature Version: 2.2
Feature Status: Evaluation (13 days)
35,759 次查看
mikedoidge
I have returned your license, when you re-activate, the new expiration date will be loaded.
Mike
68 回复数
11,311 次查看
mikedoidge
Hi @Bryan9,
I've extended yours. Please try the Refresh option in the license menu of S32 Design Studio.
Mike
11,280 次查看
Bryan9
@mikedoidge,
I tried it, but the license menu shows me the following error:
10,991 次查看
mikedoidge
Hi @Bryan9,
Sorry about that. It's extended now. Please try again.
Mike
10,970 次查看
Bryan9
@mikedoidge,
I tried again, but the same error occurs.
10,830 次查看
mikedoidge
Hello @Bryan9,
I checked the license server, there was one user able to re-activate with updated expiration date. It only gives me an encrypted machine ID so I cannot tell who. There were a number (about 20) of expired licenses from prior activations. I manually returned them so now there is just the 1 license. Try again. If that doesn't work, your trusted storage may be corrupted and needs to be re-initialized. To correct this:
Windows host:
-> Delete 'C:\ProgramData\FLEXNet'
This folder may be hidden by default, so then it would be necessary to change Windows Explorer settings to show hidden items.
Linux host:
/usr/local/share/macrovision/storage
Mike
10,793 次查看
Bryan9
Hi @mikedoidge,
Works now.
Thank you so much for your help!
11,302 次查看
thomaswhitburn
I have the same problem.   Can I have my license for S32 Design Studio for ARM V2.0 extended?
10,389 次查看
jiri_kral
Hi Thomas,
Your license expire on 9/22/2026. Please return existing license and activate S32DS again.
Jiri
11,135 次查看
mikedoidge
Hi @thomaswhitburn,
I checked your account. You have an entitlement which is valid through 2026. There are no licenses listed. So either you haven't activated it yet, or you successfully returned the license(s) you did have. Is there an issue I could help you with?
Mike
11,128 次查看
thomaswhitburn
I see an entitlement and license expiration of 9/22/21 in my License List page.  When I try to use the old activation code in the IDE I get this error:
11,027 次查看
mikedoidge
Hi @thomaswhitburn,
I understand now. You are still using the v2.0, even though you now also have the v2.2.
I will extend your entitlement for the v2.0, but I encourage you to upgrade to the v2.2. However, if you are working with the S32K1xx family devices, I would recommend that you migrate to the S32 Design Studio for S32 Platform v3.4. This is our latest version and is upon which the recent and future updates have been and will be made going forward.
Mike
11,257 次查看
cheoljin
My license also expired.
Would you extend it ?
Cheol Jin.
11,684 次查看
p_a_u_darshana
My license is expired already. How can I get the new license key from the download page?
Or is there any way to update the current license?
Thank you.
11,590 次查看
mikedoidge
@p_a_u_darshana,
Your license has already been extended through 2025.
I checked your account and manually returned the expired license. Now you just need to re-activate using the same activation code you used before. It was provided to you via email and as well you can locate it from the download site after you log on NXP.com
Please let us know of any further difficulties.
Mike
11,890 次查看
609510318
Thanks.I try to  return  license, but the error happens as follows.Could you help me to solve it?
35,760 次查看
mikedoidge
Mike
4,817 次查看
yang1226
I also have the issue.Please help me! License Applicable to Product(s): Version Description 2.2 S32 Design Studio for ARM v2.2 License Quantity: 1 Fulfillment ID: 178522127 Expiration Date: Oct 25, 2021 Product: S32 Design Studio for ARM v2.2 Machine: 103B26C08EF6E153BF6139C6980DF0031D20C7F4 Activation Code: A9C8-553D-54C6-ABAC
6,558 次查看
Romeo
Hi Mike,
I made an automotive product using S9KEAZN8AMFK.
I know that S9KEAZN8AMFK is AEC-Q100 Grade 1.
And the company we supply products to says they need an AEC-Q100 Grade 1 certification test report.
I must submit proof that S9KEAZN8AMFK is AEC-Q100 Grade 1.
Can you send me the AEC-Q100 Grade 1 certification test report?
romeo
7,044 次查看
JunSeoHan
Can I get my license renewed for S32 Design Studio for Power Architecture version 2.1
License Quantity: 1
Fulfillment ID: 204206657
Expiration Date: Jul 25, 2023
Product: S32DS-PA_v2.1
Machine: 483388A23C18B58170F1C714DC44DCB778407246
Activation Code: 1F53-8519-116C-C730
7,014 次查看
Mehul_Patel_NXP
Hi, @JunSeoHan
I have extended your license through end of December - 2026.
Please re-activate it, so the new expiration date will be loaded.
- Mehul
8,579 次查看
chrislin_wpi
Dear Mike,
My license is also expired.
Would you please help me?
ActivationId: 6BE2-D0D8-F807-B0E7
Evaluation Days: 1431
Feature Version: 3.4
Feature Status: Evaluation (1431 days)
